Collaborate forum
Door Legend in Presentation Mode - AC24
Scott Bulmer
Greetings. I cannot find the setting to remove the presentation shading from the Door Legend. I need the legend to be lines only, no shading. Please let me know if this is possible. Thank you, Scott
AC25 v. 5005 w/ MEP, Cadimage, Twinmotion 2021 using AC from AC6.0, 2.7 GHz 12-Core Intel Xeon E5 (OS X 12.2.1 Monterey), AMD FirePro D700 6GB, SSD, Artlantis 2019, Adobe CC. Used AC on both platforms.
1 ACCEPTED SOLUTION
Solution
Scott,
The Options Bar at the bottom is not displayed for Schedules so you may display the Quick Options Palette and you will see the Graphic Override Combination currently active.
But the best way is what runxel said: save a View and activate that to generate the Schedule so it looks the way you want.
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
3 REPLIES 3
runxel
Ace
It's not as intuitive, but the interactive schedules take the settings from the last opened view.
Also you should then save a view of the schedule with your preferred view settings.
Make a GO where all fills are set to transparent, if you haven't already, then assign this GO to the view. Voilá! There you have it like you want.
AC 24 [ger] | Win 10 | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
Scott Bulmer
Hey Runxel, thanks so much, it worked~! Funky way to achieve the desired setting however, perhaps GS could make it a little more intuitive. Scott
Solution
Scott,
