In that case probably the easiest way would be to go to the Property Manager Dialog and create a new property called "Door Type" for all Doors. The Property should be the "Option Set" type and you can simply manually define the options for it (Folding, Hinged, Sliding).
Then you can use that Property as a Criterion in the Scheme Setting s Dialog, while use the ID as a Schedule Field.
Here is the full playlist about Properties:
https://www.youtube.com/playlist?list=PLnXY6vLUwlWWXsVJ3fRGNxuKLoHPkpx1I
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
