2021-03-02 05:37 PM
Solved! Go to Solution.
2021-03-02 05:42 PM
2021-03-02 05:46 PM
Barry wrote:Oh boy did not think of that at all, was just using an old template, must have set up that view incorrectly in the past. Thank you this solves my issue!
I am assuming you have created a view for the schedule.
Open the settings for that view and see if it is set to use a renovation filter that shows new elements.
2021-03-06 10:03 AM
2021-03-08 05:08 AM
LaszloNagy wrote:Hey Laci,
I have experimented with this a little bit and I am pretty certain that there is a bug in AC24 (build 4007 INT FULL).
In the attached ZIP file there is an MP4 video that shows me activating each default Renovation Filter while in the Schedule Viewpoint.
It can be seen that the "04 Change Plan" filter does not display Demo elements, whereas it should display them overridden. It seems that it gives the same result as the "05" New Construction" filter.
Also, after activating the "05" New Construction" filter, which shows New elements overridden, if I then activate the "06 Planned Status" filter, it gives the same result as the "05" New Construction" filter.
This happens both in case I generate a Schedule, then switch from one Reno Filter to another in the Reno Filter Palette or the Quick Options Palette, or if I save Views of the Schedule with each separate Reno Filter applied and then activating those Views one after the other. The bug is occurring in both cases.
I will report this to GRAPHISOFT.
RenovationFilterBugInSchedule.zip
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2021-03-09 04:43 AM
2021-03-09 02:17 PM
2021-03-11 05:11 AM
LaszloNagy wrote:Hi Laci,
Hi Minh, I tried your suggestions.
1. In case I uncheck the "Hide Door/Window/Skylight/Opening Symbol" checkbox, the situation is indeed better as the "04 Change Plan" Reno Filter now correctly shows demolished items, correctly overridden in color. This is the case with the "00 Show All Elements" filter as well since the checkbox is checked there as well by default. However, override issues still remain even after I make sure that no Reno Filters have the "Hide Door/Window/Skylight/Opening Symbol" checkbox checked.
2. I still have issues with elements staying randomly overridden after I activate a filter in which a Demo/New element Override is active, then activate another filter in which it should not be, but the override color sticks.
So I think there is more to this. I do not see how it is possible to use the "Rebuild and Regenerate" command in a Schedule. I can only either close the Schedule Window and reopen it (the override stays) or click the Control button at the top left of the generated Schedule and use the "Rebuild Schedule" command (the override stays).
So, in such as case, the only way I can restore the correct operation is if I activate a Filter in which nothing is overridden AND which does not display elements that were previously overridden. So, for example, "05" New Construction" has New elements overridden. I have to now activate "01 Existing Plan" because it has no override and it does not display New elements, then I can activate "00 Show All Elements" and it will show correctly, with no override stuck on the New elements.
So, in summary, I still believe that this is something that should be looked at by development because users cannot be expected to be aware of such convoluted workarounds if the override gets stuck in a Schedule.
Minh Nguyen
GRAPHISOFT
2021-03-11 07:12 AM
DJ wrote:Hello David,
We have been having an issue where the door numbers do not update in the schedule but do on plan. When opening the object it resets and shows correctly. The issue happens randomly, and was not an issue in AC 22 or earlier with the same plans.
We are a project builder and have 180+ master designs which are kept in v22 as we have external consultants we sometimes use who have not made the jump.
Does anyone have any ideas?
Minh Nguyen
GRAPHISOFT
2021-05-13 11:23 PM
