Collaborate forum
Door & Window Schedule Add Fields...
Tincan561
In the out-of-the-box Archicad 22 template, in the door & window schedules the width and height are set by fields "A" and "B". The door thickness is controlled by "Panel Thickness"
How does one access these fields?
If I delete and try to re-insert them with Add Fields... they are no longer available.
Archicad 26
Macbook Pro, Catalina 10.15.7
poco2013
Under the ADD button select the drop down arrow and then library part Parameters.
under your library - probably Object library 22 -- openings. Select the door style and it will list the available parameters. The lower right pane will show the parameters already selected so it might be a good idea to note the variable names before you delete them as many parameters names are similar.
Gerry
Windows 10 - Visual Studio 2019; ArchiCAD 26
Tincan561
Thank you.
Archicad 26
