Door & Window Schedule
I'm working on a project with a split level between cellar and 1st Floor (7' from cellar and 3'-4" from 1st Floor). Doors that are on this Split level are shown on 1st Floor door schedule but I want them in cellar door schedule. All walls and doors home story is cellar level. PLEASE HELP. THANKS
3 REPLIES 3
I find that if the door is more than half way above the higher storey then it will schedule in that higher storey even though placed and anchored to the storey below.
I am not sure there is a solution to this.
You can probably manage that with layers, layer combo, and schedule Criteria.
Katalin Borszeki
Hi, this issue has been added to our database already. Please see the linked article to clarify and to provide a workaround solution.
http://helpcenter.graphisoft.com/troubleshooting/documenting/unexpected-labelingscheduling-of-openin...
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
http://helpcenter.graphisoft.com - the ArchiCAD knowledge base
Learn and get certified!
