Door and window builder question
I have a project where I have been using double hung windows with door and window builder. The problem I am having is that I have not been able to find a way to have divided lites on the bottom sash. Does anyone have a solution to this? Thanks for any advice.
11 REPLIES 11
Thanks for the email address - I have added it to my address book. Keep up the good work. I hope that door and window builder will continue to develop because its approach seems like the ultimate solution...
Chazz
Agreed. It is a complex product but the results can be tremendous. Changing a single parameter (a sill treatment for example) in an entire multi-building development feels very powerful.
However, DWB is sometimes complicated to use and I have had VERY repeatable errors that can bring down AC, which is a little scary for a lib part. I have struggle with the exact issue you noted here and frankly could not recall the solution I eventually discovered.
I would urge Cadimage to continue refining the product and would also remind them that customer support is part of the tool.
Nattering nabob of negativism
Learn and get certified!
