Collaborate forum
Door and window schedules with nominal sizes in inches only?
artktecture
I have a client who wants the door/window markers on the floor plan in inches only
eg. 36"x80" for a front door instead of 3'-0"x6'-8"
I modified my dimension settings to do this but in my door/window schedules the scheme setting for nominal width x height only shows in feet and inches.
Is there any way to change this?
artKtecture uses Archicad 24/Twinmotion
Lenovo Thinkpad | Xeon E2176M@2.70 GHz | 32GB | Quadro P4200 8GB
Oculus Rift S VR tours
Contour Rollermouse Red Plus (ditch your mouse and get one of these!)
Using a highly modified Shoegnome template (Thanks Shoegnome!)
3 REPLIES 3
Go to the "Options > Project Preferences > Calculation Units & Rules" Dialog.
In the "Length Unit" field, select the "fractional inches" option.
Does that give you the desired result?
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
David Maudlin
artKtecture:
Schedules have View settings. So In Project Preferences set up a Dimensions set that uses Fractional Inches as the Unit, then apply it to the Schedule's View settings.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC26 USA • iMac 27" 4.0GHz Quad-core i7 | 24 gb ram • MacBook Pro 2.8GHz | 16 gb ram • OSX10.15.7
artktecture
LaszloNagy, that did not change anything - I had it set to decimal inches already.
David Maudlin, Thanks! That was easy. Not sure why I didn't think of looking there to change the settings.
