You would need to script your library parts to ignore the frames and casings in the schedule view.
This is not an option at present but can be done.
But if you are using the default Archicad library then this will be tricky because of the way they are scripted and then you will be back to square one when ever the library is updated.
Or place separate door leaf objects in your model that you could schedule.
But this will require a lot of extra work.
