I replied in a PM but for those following along here ...
You can't open a Drafix (.CAD) file directly in Archicad.
It has to be saved as a .DXF file first.
So you will need Drafix to do that.
The problem is I am not sure if Drafix will run on a modern machine/OS.
I am pretty sure it doesn't.
However Autosketch which took over from Drafix can.
If the clients just want a copy then obviously you don't need Archicad at all.
Just open in Drafix/Autosketch and print.
If you need to modify the plans then best done in Drafix/Autosketch as it will all just be 2D line work.
If you need to make a 3D model then yes you will need Archicad.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
