Archicad Python API
About automating tasks in Archicad using the Python API.
Dynamic ID Coding of Building Elements
Patrick Sherwood
Is there a way to define the ID of 3D elements (walls, slabs etc.) with some of its own properties .
eg. Wall = [Composite Name] + [Fire Rating] + [STC].
All of these have been defined, so would like a way to automate this rather than selecting all walls and changing manually.
Have tried the Element ID Manager but seems to only work to increment walls individually/or part of group and doesn't seem able to dynamically create IDs.
Thanks
poco2013
Mentor
I make a short Demo video to show a Python script to accomplish this.
Convert Element ID to new title based on three properties of the element
Attach is the script. Leave a comment if you have further questions.
Gerry
8 REPLIES 8
poco2013
Mentor
AFAIK - This is not possible with the "built in"tools in Archicad. You could create a new property using a expression which would create the new Id, but you could not overwrite the "element ID" property which I believe is your intent.
There are a few alternatives.
You could export a schedule to excel. Create a macro there to overwrite the Element ID field then re import into Archicad.
You could create a C++ AddOn to directly overwrite the "element ID"
Or the easiest, most straight forward way would be to create and use  a Python script. The script would involve only a few lines of code and would offer the most control over the logic, filtering and formatting.
Gerry
I would like to know how this python script would be written.  I am also interested in writing specific information to the elementID field.
Kind Regards,
Sebastian Monroe
Director/Architect
T: +61 3 9017 6666
www.codearchitecture.com.au
NOM ARCH VIC ARB: 17939
Archicad v26, Mac Mini INTEL 64GB, AMD Radeon Pro
Does the element id manager not do what you are after?
poco2013
Mentor
Gerry
_c_
Hello Gerry, many thanks for your very useful example.
Here I attach a variant avoiding the extra modules. Also there was a missing property (we are on the German AC) causing error.
This might be useful to others.
_c_
The video is set to private, I'd love to see it.
Jared Banks, AIA
Shoegnome Architects
Try it now?
Gerry
Thanks. It works now.
Jared Banks, AIA
