Project data & BIM
ELEMENT ID MANAGER "FILE"
daviddelven
Where can I find the "element ID manager" FILE in the computer installation ?
Thanks
David Delgado Vendrell
http://www.daviddelgado.cat
i7-7820HK CPU 2,90GHz 32GB RAM
Triple Monitor 17"+25"+32" Nvidia Geforce GTX 1080
SSD+HDD, Win10 Home - 64 ENG
AC18-AC26 INT/SPA (64-bit, latest build)
Surfing with Archicad since 2013
1 REPLY 1
I don't think it is a file you are supposed to play with.
As far as I can tell it is here ...
C:\Users\your_user_name\AppData\Roaming\Graphisoft\EIDM Settings 20.6005\EIDM Settings.bin
You may have to unhide the APPDATA folder in the settings as it is a hidden system file.
I would recommend that you don't touch it unless you really know what you are doing.
