Element ID Manager Standardising
JGoode
Hello,
We're trying to set up presets for the element ID Manager in AC23 but they don't seem to be linked to the file and are stored locally. Has anyone else previously tried to do this? Is there a way to add presets so that they can be standardised? If they are stored locally, where are they stored?
Thanks!
ArchiCAD 23
Windows 10
2 REPLIES 2
Podolsky
Ace
Interesting question. I found on Graphisoft help web page mentioning that it does save into local file. But where? I cannot figure it out.
I have just checked this (using Ac24 build 5000) and I found the following folder:
C:\Users\<UserProfileName>\AppData\Roaming\GRAPHISOFT\EIDM Settings 24.5000
So, you need to find the following folder:
In that folder, the program creates a folder with its version and build number in the folder name when you first activate the Element ID Manager Dialog, so the folder name will be similar to this:
After you modified any of the settings in the Element ID Manager Dialog and quit the Dialog, Archicad stores Element ID Manager settings in a file called
EIDM Settings.bin
So, you would have to move this folder and the file in it from one computer to another to synchronize settings across your office machines.
On the Mac, it is probably stored in a similar location, a Mac person may be able to post exactly where.
Learn and get certified!
