Q1a: EIDM is rather primitive and has no ability to filter by criteria other than the originating tool...v9 and v10 (and v8.1...) are the same. Has never been improved since it was introduced.
Q1b: To not list empty openings, assign them a special ID (blank, e.g.) AFTER using EIDM to renumber everything and set your schedule criteria to allow all ID's except that one, e.g.:
ID<>"" This is discussed here and there over the years in these forums.
Tip: Quickly change the ID of all empty openings on all stories with a special schedule that filters just empty openings... or use Find and Select in 3D to select them all at once.
Q2: All stories will appear in your schedule unless you specifically include a criteria to only include a certain story...OR if you have selected all walls on the current story in v9. (In v10, selection has no effect.)
Karl
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
