Enlarged text height in external drawing from dwg import
Takis
Hi, when I try to import a 1:100 scaled dwg file as an external drawing the imported text and labels are anlarged by double (depending of the autocad file scale the enlargement may be bigger).
To achieve the same text height I have to either change my scale in Archicad (for example from scale 1:100 to scale 1:50), or make the text in Autocad smaller (i.e half of its original size).
If a dwg file which its scale is 1:250 then in the imported external drawing into Archicad the text height will be 4 time larger, so in this case to see the text properly in Archicad the view scale should be 4 times bigger i.e 1:62,5.
This enlargement does not happen when importing the dwg file as an Xref.
I have checked the dwg translator in Archicad but I did not find any parameter in there which refers to text height.
Any ideas please?
3 REPLIES 3
Hello! I have the same problem. I imported DWG drawing as "place external drawing" and the text height went out of scale. In drawing option there is not possible to change the external drawing scale (or text size). Any ideas?
Go to the DXF-DWG Translation Setup Dialog, and in the Settings panel, under Drawing Units, experiment with the "Set Scale Factor for Importing Texts and Arrowheads" options. Maybe, set the first option so you can set the Scale Factor while placing the DWG file. Hopefully you can find the correct setting for your Text Sizes.
DGSketcher
Legend
When importing a DWG file ensure the current view scale matches, so a 1:100 scale DWG drawing will import text at the original size if the view is also set at 1:100. Thereafter the font will scale as in AC according to the view scale setting e.g. at 1:50 the imported text will be half the size and at 1:200 the text will double in size.
