Collaborate forum
Error Exporting model to DWG format
We are using Constructor and are trying to export a model file to DWG / DSF format so we can open it in another program (Navisworks). The process shuts down Constructor and the error getting displayed is "Not Enough Memory". I am trying to export the whole model from the 3D window. Has anyone seen this error before. I'd appreciate any pointers on how we can resolve it.
I know there is a utility which allows ArchiCAD 9 model files into a .NWC or Navisworks compatible format. Is there something out there for Constructor? Please let me know.
Thanks in advance for the help.
Atul Khanzode
DPR Construction, Inc.
atulk@dprinc.com
2 REPLIES 2
Djordje
If the export engine runs out of memory, then - depending on how detailed your model is - it might be that you are actually out of memory. Check your computer specs.
Also, in Constructor, you do have the Check model complexity. Stuff like round door knobs have gazillions of polygons, that are quite not necessary.
It is a very long time since I exported a NavisWorks model, so you will have to wait for an expert advice ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Constructor (nwc exporter, same as Archicad) will be supported in the next navisworks release, v5, due (I am told) by end of this month/beginning April.
