Export an AC composite wall as solid in IFC?
Mats_Knutsson
Is it possible? I've tried the IFC-settings under geometry conversion but the composites show in the IFC. I want it as a solid wall.
Mats
AC 25 SWE Full
4 REPLIES 4
I checked the Geometry Conversion settings but I don't think it is possible to do with any of the current settings.
Make a wish for it if you think this would be an important and useful addition.
Maria Calogeropulos
Hi, is there any solution for this now? Our client wants to have a simple wall solution and I would like to not have to change all walls to basic.
Thanks,
Maria
Maria, which ARCHICAD version are you using?
The answer may be dependent on the AC version.
Laszlo
You said that it is dependent on the AC version, could you be more specifik?
We need to do a similar export due to client requirements.
Is this at all possible?
We are using all versions of Archicad if it helps
Erik Bjornhage : SwedishChef, ETTELVA Arkitekter, Gothenburg, Sweden
Architect : Digital Development : Graphisoft Cert. BIM-Manager
ETTELVA Arkitekter : Eriks LinkedIn
DELL Precision 5570; i7-12700H; 64 GB; RTX A2000 [8GB] : AC12 - future
Learn and get certified!
