Exporting DWG with Xref
Lukas Zeleny
I have placed some xrefs in floor plan and made independent worksheets. When I save dwg from these independent worksheets Archicad saves also xrefs placed in floor plans. Tested in AC21 and AC23. It seems that Archicad always saves all xrefs used in file regardless of its relationship to exported drawing.
My translator is set to save single dwg. How can I save only one dwg?
BIM Manager at SIEBERT+TALAŠ
www.sieberttalas.com
1 REPLY 1
Ahoj Lukas!
Have you tried changing Settings for the Xref location?
It might be that you have selected the option "Copy attached Xref in the folder next to host DXF/DWG". I think that is the default option.
Martin "from Stockholm"
