2019-02-05 03:50 AM
2019-02-05 03:53 AM
2019-02-12 03:15 AM
2019-02-12 05:40 AM
2019-02-14 12:21 PM
B.E.A.T. wrote:
Aparently, the reason for this would be that the Archicad-export isn't fully ready for IFC4 at this moment. Personally, I find this hard to believe (considering - amongst others - this recent FB-post:
https://www.facebook.com/archicad/posts/10156402879118043
Any thoughts?
2019-02-19 05:16 AM
felcunha wrote:Want I want is all Building Material Properties (Physical and non-physical) to get translated to IFC in the same way. As screenshots (from BIMcollab ZOOM) show in my initial post, stuff like 'embodied carbon' has a
Just to understand:
You want to have common properties for your materials but no IFCPropertySingleValue?
And if you just for checking, edit and delete the lines containing these single values ?
2019-02-19 11:31 PM
B.E.A.T. wrote:I'd like to help but I can't... If I create an IFC file using Archicad I'll see all the material properties as "IFCPROPERTYSINGLEVALUE", including 'Embodied Carbon'. (By the way the value you get for it in the "component properties tab is also a single value)
Want I want is all Building Material Properties (Physical and non-physical) to get translated to IFC in the same way. As screenshots (from BIMcollab ZOOM) show in my initial post, stuff like 'embodied carbon' has ageneralparameter (which makes it usable for Smart Views in BIMcollab ZOOM), while Building Material ID gets translated into specificparameters like Buildingmaterial1.ID, Buildingmaterial2.ID, ...thus making it completely useless for further analysis of IFC (in a viewer like BIMcollab ZOOM).
Hope this clarifies my question...
It could be a BIMcollab ZOOM issue (I've asked the same question there), but I get more or less the same results in Solibri Model Viewer for instance...
2019-04-12 06:27 AM
2019-05-15 12:13 PM
2019-05-16 07:16 AM
