SOLVED!
Expression Formula / Units display
Hi all,
I am very new at writing expressions so forgive me on my newbie question.
I am trying to write some expressions for some schedules. I would like to display the size of a "post" as one field so I would like it to read 8X8 for the size but it is reporting a 0'-8" x 0'-8". is there a work around to remove the 0'-?
Thank you for your time.
John
1 ACCEPTED SOLUTION
Solution
Eli Chiasson
It seems Expressions take their settings from Project Preferences > Calculation Units and Rules
I found one thread that brought up the difficulty of only being able to control Schedule units though a global project setting, but it seems that's the current state. That said, I was still able to get the result you want:
This is the Expression I used:
CONCAT ( STRCALCUNIT (Core Width), " X ", STRCALCUNIT (Core Depth/Diameter))
Eli Chiasson
Dexel Architecture
http://www.dexel.ca
AC19-23 USA+MEP • i7-7700 3.6GHz | 32GB RAM • Windows 10 Professional
4 REPLIES 4
Eli Chiasson
Hi John,
Under Project Preferences > Dimensions you should see this:
Select the option I've highlighted to get the result you're looking for. You'll need to save this as a standard and apply it to the View of the schedule you create, I believe.
Eli
Eli Chiasson
Dexel Architecture
http://www.dexel.ca
Hi Eli,
Thank you for responding. I currently have that setting chosen and that does not seem to do anything to the schedules.
Solution
Eli Chiasson
Eli Chiasson
Dexel Architecture
http://www.dexel.ca
That's it! Thank you very much for your time.
