In the Property Manager, are the Properties made available to elements with Door/Window Classification?
There is a trick that every Property that is used in the Expression must also be made available to elements with Door/Window Classification. This may actually be the reason why no value is returned in the schedule.
If not, can you show a screenshot of the Scheme Settings Dialog where you define the Criteria and Schedule Fields?
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
