Collaborate forum
Expression based properties in door/window schedules
ddori
Hello!
I created expression based properties to create automatic ID-s to my doors/windows. They work fine with autotext and automatic labels, stamps. (as you see on the floor plan)
However, in interactive schedules I can't list them.
Do you know any problems that can cause this? They even don't work with the find and select window 😕
Thanks for your help:
Dora
2 REPLIES 2
In the Property Manager, are the Properties made available to elements with Door/Window Classification?
There is a trick that every Property that is used in the Expression must also be made available to elements with Door/Window Classification. This may actually be the reason why no value is returned in the schedule.
If not, can you show a screenshot of the Scheme Settings Dialog where you define the Criteria and Schedule Fields?
Laszlo Nagy, Lead Moderator, Community Admin
AMD Ryzen 1700X CPU, 48 GB RAM, NVidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
ddori
Yes, I paid attention for every Classification of the Properties that are used in the Expressions.
My Scheme Settings Dialog looks like:
