Collaborate forum
FBX or Twinmotion for ArchiCAD 25
Rex Maximilian
When will we see an export option to FBX or Twinmotion for ArchiCAD 25? At the very least, FBX (generic) should be included on the day a new version ships as it has become an industry standard for 3D import into rendering packages.
Rex Maximilian, Honolulu, USA - www.rexmaximilian.com
ArchiCAD 25 (user since 3.4, 1991)
16" MacBook Pro; M1 Max (2021), 32GB RAM, 1 TB SSD, 32-Core GPU
Creator of the Maximilian ArchiCAD Template System
1 ACCEPTED SOLUTION
Solution
Aaron Bourgoin
Epic have just provided the final versions of the twinmotion/datasmith connections.
https://www.unrealengine.com/en-US/datasmith/plugins
versions for 23, 24 and 25
Think Like a Spec Writer
AC4.55 through 26 / USA AC25-5010 USA
Rhino 7 Mac
MacOS 11.6.5
15 REPLIES 15
Solution
Aaron Bourgoin
Rhino 7 Mac
MacOS 11.6.5
Thank you!
2RA Building Workshop
www.2rabldgworkshop.com
Mac Mini. Apple M1. 8 GB. macOS Monterrey. 12.4. ArchiCAD 25. 4013 USA Full
Rex Maximilian
I saw that. Will try it out. However, nothing beats saving out to FBX as we could do in earlier ArchiCAD versions. I hope the datasmith plugin still allows it. Thx!
Rex Maximilian
It appears saving as FBX is out, which is a bummer because it is a universal format for 3D model interchange. But, you can save as a .udatasmith solo file and import into Twinmotion using conventional importation methods.
There's been previous discussions on the TM FB forum as to why FBX (or traditional export/import) is advantageous over direct link methods.
rjwilden
I found the direct link very unreliable, multiple crashes. FBX export very much better. Has the direct link in 25 become more stable. Will not upgrade to 25 until there is certainty with this, as TM cloud is my preferred method of presentation.
Richard Wilden Design. Ltd
Dunedin, New Zealand.
Imac 27" i9 3.6GHz; 32GB Ram Mac OS 11.3
Archicad V23:V24
Mjules
We also need the latest update displayed on the following web page: https://graphisoft.com/downloads/addons/datasmith-exporter
Martin Luther Jules
AC 10-26 (Full)
Asus | 64 GB RAM | Windows 11
Apparently there is no 'Direct Link' with 25.
You have to use the Datasmith add-on.
The one for 25 was in preview until just a few days ago.
The release version can be found here as Aaron posted earlier.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
The Release Notes page states that the Datasmith Exporter does provide a direct link to both the Unreal Engine and Twinmotion. Or do I misunderstand something?:
Unreal Engine 4.27 brings with it a new Datasmith Exporter for Archicad, the popular architectural CAD software by Graphisoft. The plugin provides support for the Datasmith Direct Link workflow, allowing Archicad users to synchronize their application with Unreal Engine and Twinmotion; as well as the ability to export data in the .udatasmith file format.
https://docs.unrealengine.com/4.27/en-US/WhatsNew/Builds/ReleaseNotes/4_27/#datasmithexporterpluginf...
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
When I say 'Direct Link', I mean the 'Direct Link' add-on.
That is not available for 25 as far as I know.
The Datasmith workflow is a little different I think - although I have not tried it yet.
The old 'Direct Link' would actually start Twinmotion and load the Archicad model.
And the Twinmotion Model could be syncronised directly from Archicad.
I don't think the Datasmith add-on works quite the same.
Versions 6.5 to 25
Then maybe it is this one:
https://www.unrealengine.com/en-US/twinmotion/plugins?lang=en
There is also a video about how to use the Direct Link. The video shows Revit, but it is probably the same workflow with Archicad:
scom570
Just updated my model to AC25 but the linking crashes ArchiCAD everytime.
Did uninstall and reinstall of the Datasmith to no avail.
BTW to get the link to work:
Open TM to IMPORT
Open AC model to 3D window. (If you don't see the Datasmith plugin you can activate it from
WINDOW, PALETTES, DATASMITH.)
The refresh icon only activates when in 3D Window.
On TM click IMPORT and Select IMPORT DIRECT LINK
A window pops up that shows the available filename of the AC drawing you have open. Click OK.
Voila, you are connected.
When you want to update the TM, select refresh on DATASMITH toolbar in AC.
Works for me in AC24 but not AC25 which crashes everytime.
Not sure if Datasmith link or direct link is better just yet but I do see how it might be more flexible for UE.
Tim Ball
I can find the Datasmith add on but when I try to add to the menu bar nothing happens.
Has anyone got a step by step install worked out yet?
Tim Ball
AC25, iMac
User since V5
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Open TM to IMPORT
Hello,
Thank you for the report and I am very sorry to hear about it!
If I understand correctly, the same model doesn't crash when linking AC24 and Twinmotion, but with AC25 it crashes every time? Did you keep the bug ID from one of the crash? I would like to know whether the issue comes from the addon or from Archicad.
Looking forward to hearing from you!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
scom570
I can try to regenerate the bug ID later today.  WRT Tim Ball's question.  Go to: WINDOWS from pulldown menu, then PALETTES and you will find it at the bottom of the list (at least that is where mine is).
Rafal SLEK
The lack of FBX format is unfortunately a big step backwards for Archicad users, it's a pity that Epic Games abandoned this format. For example, by linking an FBX file, you can automatically update and sync a model between Achicad and 3DSmax with Corona Render. Maybe Graphisoft would prepare a quick update though?
MacBook Pro Retina 2019/2.4 GHz/Intel Core i9/32GB RAM/Radeon Pro 5500M 4GB/macOS 11.6/ArchiCAD 25vINT+POL/Maxwell Render 5.2/Twinmotion 2022.1
