Fixed element ID?
How to make element ID's, specifically Windows and Doors to be fixed number? I'm trying to create a catalogue of windows that correspond to real products and each window has unique product number, which I want to assign as ID within Archicad. The problem is that ID number automatically changes +1 for every new copy of the same window I create and I want to avoid that. Please help?
vistasp
Go to Options > Work Environment > More Options and uncheck "Assign New Element ID to Each New Element"
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC 9-27 INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
You can also use the Document > Listing Extras > Element ID Manager to modify IDs of elements, for example, assign the same ID to all elements meeting the same Criteria.
Thank you, both of you!
