Google earth and 18
There is an add-on for Google Earth, SketchUp and Google 3D Warehouse Connections that shows ArchiCAD 16. Does this work in 18? I know sketch has moved on. I know we can drag and drop warehouse parts. I know I can save my model out as a KMZ file
Thanks
Eduardo Rolon
Using the File-> File Special->Merge command you can import SKP and Google Earth files into AC.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Eduardo thanks so much for showing me the way!
Cheers Cary
