Help! Translation Archicad Group to a Autocad Block
Hello ArchiCAD friends
I have a problem which would be nice to get under control since I know there must be a solution for such a simple matter.
My problem is when importing a 2D element from a Archicad group, (eg., a toilet consisting of several lines, arcs, and whatever) using the translator. When I make this DWG file the object there once were a group in Archicad don’t translate to a block in Autocad. So, I was wondering, there is a way to group 2D elements from archicad (using the group tool), translate it to DWG file, and then, into this new DWG file the group became a block?? With all lines and arcs in the same block?
I need to get this answer to be able to work with partners who use Autocad.
So, any ideas what I have to do?
Thanks for any comments or answers!
2 REPLIES 2
Link
I don't believe this is possible by simply grouping elements. ArchiCAD can translate library parts into blocks AFAIK, so you may want to try that route?
Link.
ok, i make then GDL files...
It's not the best way to do this, but i think it's the only one! ty
Learn and get certified!
