Project data & BIM
Hotlink Modules - Lineweight
Lok Hee Tang
Hi, everyone. I have a host file (Archicad 25) with a several hotlink modules inside. I am wandering how is the  host file's lineweight system affect the hotlink modules? Thanks.
mi_jan
The hotlinks you add to a host file will use the pensets from the host file, If you need to use the pen sets from the individual hotlinks, you would need to import these with the Attribute Manager from one file to the other.
That being said, if you are showing 3 hotlinks in one view, all 3 hotlinks will share whatever penset you assign that view.
iMac - MacOs Big Sur 11.6.6
Archicad 24 - Latest Build
Archicad 25 - Latest Build
mi_jan
Thank you!!
