Hotlinked RVT geometry not solid.
Sergey K_
Hello Archicad-people!
Is it normal, that Revit geometry, coming from the built-in RVT plugin is not solid in Archicad?
I mean I can see only the shell. Faces only. Revit geometry is hotlinked.
1 REPLY 1
Hello Sergueï K_,
I also saw the same case. Could it be related to the type of modeling used by revit ? Revit would use surface modeling like sketchup modeler ?
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
