How can I copy a schedule's format between projects
4hotshoes
I have several schedules that were successfully created on one project and now I would like to update my new template. Is there a cut and paste or export-import?
Todd Oeftger
AC27 Mac MacBook Pro 15", 2019, 2.3 GHz i9, 32GB, Radeon Pro 560X 4GB, 500GB SSD, 32" Samsung Display (2560x1440)
1 REPLY 1
Import -Export
You can import multiple Schedules at one time also. No risk of duplication because the program will automatically add a number to the name of the Schedule if it is a duplicate. If you import a Schedule from a newer version of the program to an older version a warning will pop up to let you know that you may need to check the schedule for fields that may not be available in the older version.
Learn and get certified!
