How can you export list schemes?
alexliz
I've worked on a project (not a template) and have set up a number of calculation lists (components, zones etc.) Trouble is, I am starting a new project now and have spent quite some time and haven't managed to find how to export-import my schemes into my new project.
Come on, people, I would hate to have to re-set all those calc lists in the new proj. I absolutely hate the Gsoft interface for calcs. Save me!
Thanks, people.
Alex Zachopoulos
MacBook Pro 17" 2.4GHz, MacOS X 10.5.6, ArchiCAD 11 & 12, WinXP, Vista (well, not really Vista...)
1 REPLY 1
Hi Alex,
No you don't have to redo it. In the Int. version of AC 9 the text file that contains all list information can be found under the User folder.
Please see my attached pict, including my copied "test" list / the opened text file where the very same test list could be found and the search path on a Mac - if not changed under the Work environment settings.
As long as you've done a save before starting a new project this text file should include your new list. just make sure it is loaded when looking for it.
