Collaborate forum
How do I load MEP library?
Greetings guys,
I just started using Archicad MEP modeler and I wanted to give it a go and build a simple system just to test the software. But I am unable to do so because I cannot seem to find the pipe/duct library. Can you please help me find it? It should be straight forward I think but I guess I am missing something. Best regards,
3 REPLIES 3
milangomes:
Look at Applications > Graphisoft > ARCHICAD XX > MEP Library XX. Use the Library Manager to load the library.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC26 USA • iMac 27" 4.0GHz Quad-core i7 | 24 gb ram • MacBook Pro 2.8GHz | 16 gb ram • OSX10.15.7
vfrontiers
Loosely related... How do you UNLOAD MEP Modeler?
I tried just unchecking in ADD ON MANAGER, but you can't.
I tried just removing the MEP Folder from the ADD-on folder, but it won't start archicad without it in there.
I find MEP of no use to me and when installed it takes over some of the base cabinet objects making it so I can't change a 2-Door Base Cabinet into a Multi Drawer Base because the drawers are not MEP blessed...
Any advice would be helpful!
Duane
Visual Frontiers
AC25 :|: AC26 :|: Enscape3.4:|:TwinMotion
DellXPS 4.7ghz i7:|: 8gb GPU 1070ti
The MEP Modeler is a separate installation.
So I would suggest that you use the Uninstall command to remove it.
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
