loann_vu wrote:
Is there a work around for this?
Not one that I can think of.
loann_vu wrote:
Do I need to break each object apart into separate objects?
Yes, every object that you want to schedule will need to be a separate object with the necessary parameters/properties that you want to schedule.
loann_vu wrote:
Is there a different criteria I should use?
No it has nothing to do with the criteria.
You just need the criteria that will select all of the objects you want to schedule - which is sounds like you already have.
The problem is you need individual objects.
