How to collect surface areas of all used materials?
How to collect surface areas (m2) of all used materials for example of one room.
Room contains 2 beams in ceiling. Slab on the ground and one to the next level. 2 columns.
Let's put it this way. I have walls painted in one color. Beams in other and columns in different.
The question is - is that possible to calculate all painted areas in one scheme using Zone - or I must set up one Scheme adding Reference Side Material and Oposite Side Material, then adding each Element's all side areas->Surface Of the Wall on the Reference Line Side and Surface Of the Wall on oposite the Reference Line Side and so on for slabs - beams and columns?
0 REPLIES 0
