How to create a Door Schedule with fire rated doors?
I noticed that there is no way to add the "Fire Rating" of doors to any Door/Window schedule...
How is it possible to obtain the fire rate of doors in a schedule/list?
Mac OSX 13.6.4 | AC 26 INT 3001 FULL
5 REPLIES 5
If "Fire rating" is a parameter in your door objects then you can add that parameter as a field in your schedules.
Thanks Barry!
I have set a fire rating in the "Parameters for Listing" tab in the doors.
How do I add the "Fire Rating" value to the Schedule?
I can't find it...
Dave Seabury
Open your schedule, go to "scheme settings", at the bottom of the window
(v13) is "additional parameters", work your way to your door and add the
parameter that you want listed.
Hope that helps
David
AC 19-24 Windows 10 64 bit, Dell Prercision 7820, Xeon Silver 2414R ( 12 Cores), 64 GB Ram, Quadro RTX 4000 8GB
In "Scheme Settings/Fields/WindowDoor" find Fire Rating and add.
OK thanks everyone.
