SOLVED!
How to create drop-down or check-boxes in schedules.
As I ask in the title, I've never seen any details on how one makes these, or adds these – if there is a place where one can add them from in the Scheme Settings/Add Fields.
Any tips?
1 ACCEPTED SOLUTION
Solution
poco2013
Mentor
Not sure if there is more to your question but on the surface.
Drop downs are not created within schedules. they are simply a type of property created by the property Manager. The drop down options are created within the property manager together with a default. When the property created is selected in a schedule, assuming it is attached to the object, it is brought in as a drop down together with all of the options or the default. The drop down option can then be selected either in the schedule or the object.
See Property Manager in the HELP.
Are you asking about something else??
Gerry
Windows 11 - Visual Studio 2022; ArchiCAD 27
5 REPLIES 5
Solution
poco2013
Mentor
Gerry
Yes, I was also asking about the check boxes, also shown in the screen shots.
Strange to say, but I've never used tis option before, I guess I need to play with this.
borki,
Watch these 4 short clips on YouTube (about 10 minutes overall). They talk about the various Data Types that ARCHICAD Element Properties can have. As you know, these Properties appeared in AC20, and they can be listed in Schedule Fields.
If you specify that a Property's Data Type is "Option Set", you can define that Option Set in the Property Manager and when that Property is scheduled, that set of options will appear in the Schedule as a drop-down list, and you can select any of the options from the list to modify the Property's value.
If you specify that a Property's Data Type is "True/False", when that Property is scheduled, you will see a checkbox appear in the Schedule and you can check or uncheck the checkbox to represent a True (or YES or 1 or ON) or False (or NO or 0 or OFF) value or state.
https://www.youtube.com/watch?v=QSa7obNjGO0&index=5&list=PLnXY6vLUwlWWXsVJ3fRGNxuKLoHPkpx1I
https://www.youtube.com/watch?v=BbyuGgrU3qs&list=PLnXY6vLUwlWWXsVJ3fRGNxuKLoHPkpx1I&index=6
https://www.youtube.com/watch?v=8xtgXijkWOo&list=PLnXY6vLUwlWWXsVJ3fRGNxuKLoHPkpx1I&index=7
https://www.youtube.com/watch?v=Hv7qSceRkGU&list=PLnXY6vLUwlWWXsVJ3fRGNxuKLoHPkpx1I&index=8
Thanks Lazlo:)
The information really helps explain the functionality and I hope to utilize this:)
I wonder, will this information transfer over in IFC or will there need to be some special configuration here? I'm a bit curious as it seems that both this, IFC, and attributes section could be merged into one area.
One more question regarding schedules: I've been interested in collapsing my door and window schedules to show the individual instances of each element. I've also needed to keep the room/zone name and number to be able to locate these elements efficiently, so just about every instance of an element is an individual entry in the schedule.
I would rather not have a manual work around to list all these locations in one cell, so I've been pondering if there is a way to collect this automatically, and can't find a way to do so.
With the location, room and number, there seems to have been a workaround changing parameters in the GDL, but that seems to no longer work:
https://archicad-talk.graphisoft.com/viewtopic.php?t=48107
With regards to how one does this, I thought there might be a way to use Tags from the Property Manager to do this, but I would still need to have that info called from somewhere and would be redundant to using the properties that list that information. But then there seems to be no way that multiple instances of some information can be collected together anyway. So then what ? The Sum functions in the schedule can only be used for column numbers/integers throughout a column, but not for text in one cell... ?
Learn and get certified!
