How to insert ifc properties into the mapping rules ?
felcunha
Hello all,
I'm trying to map my IFC elements with rules, and I'm struggling to insert some properties who aren't documented in the objects.
Let me explain : I have to create a IFC file where the name of the objects have specified parameters. Windows, for example, have to show their dimensions (which I can find in the objects properties) but I can't find how to show and insert the number of casements...
Any idea ?
Thanks in advance,
Felipe
Felipe Ribeiro Cunha
AC 26, macOS Monterey
4 REPLIES 4
I hope this clip helps:
https://www.youtube.com/watch?v=d8V3I5OfgK0
felcunha
Thanks, but I could not find any object's property with tells me how many panels my windows have !! Would someone know where I could fill this information other than putting it manually ?
I don't think this is a piece of data that Windows have available.
You would probably have to modify the Window object's Script, create a new parameter for this and calculate it in the Script. Then you would be able to map that value to an IFC Property.
felcunha
Thanks for the information.
Regards,
Learn and get certified!
