2021-07-28 01:12 AM
2021-07-28 01:21 AM
Noémi Balogh
Customer Engagement Expert, Community Admin
2021-07-28 03:24 AM
nbalogh wrote:
Hi Karol,
Yes, you can setup an HTTPS environment for your BIMcloud. What you need here is a well configured reverse proxy (by default BIMcloud components can communicate with each other via http only, so you need a middle layer to be able to setup such environment between Archicad clients and BIMcloud components).
An important note here is, that many people forget to give access both to the BIMcloud Manager and BIMcloud Server. If Archicad cannot communicate directly with both components, it first causes performance issues, and later can cause even error messages and failed operations while working in Teamwork.
You or your IT might be interested in our BIMcloud for IT Professionals training on the Graphisoft Learn portal, where you can learn more about the requirements:https://learn.graphisoft.com/instructor_modules/list/23595
Noémi
2021-07-28 08:46 AM
Noémi Balogh
2021-10-20 08:34 PM
Hey Noemi, how can I set https in BIMclooud ? can you sshow me step by step? Even I enroll the Graphospft learning portal, it takes time to watch all videos, that will be too late for my schedule. Thansk a lot.
2022-12-01 03:31 PM
We have the same situation here. Just looking for a guide on how to set up as this should be set and forget so not really looking for training course.
Most likely companies will have external IT support and might be inconvenient and expensive to pay for their time taking the course.
