I did see an interesting method pop up on a linkedin article yesterday, the whole thing is in Dutch, so I'll try to briefly outline the method descibed.
You can set up building materials to not participate in collission detection and you can export IFC to not include those building materials.
The workaround proposed there is to export several IFC files of:
1. single bits of building material where you want to have them as separate elements in IFC
2. the model without those elements (works best if you can filter out layers).
Merge all these IFCs together in solibri.
This way you can keep your composite and complex profiles with several building materials and still have them as separate bits in IFC.
I could see this work where you hotlink the 'main / master' PLN to several 'export only' PLN files where you have altered the building materials to not participate in collision detection, except the one you wish to export. Set up a publisher for quick export.
Still a workaround, but your model is much more manageable on the archicad side of things.
www.leloup.nlArchiCAD 9-24 NED FULL
Windows 10 Pro
Adobe Design Premium CS5
