2022-07-10 08:35 AM
Solved! Go to Solution.
2022-07-10 09:31 AM
It means that the photo of the texture is missing. you can select the mesh and check the texture. or assign a new material.
2022-07-10 02:32 PM - edited 2022-07-10 02:33 PM
As Ady84a said, check out the surface texture that has been used for this mesh, go to option > attribute manager > surface > click on the mesh surface > click on the arrow and then browse texture > change the image or load image or texture from library:
2022-07-10 09:31 AM
