Collaborate forum
IFC 2x3 file conversions
I have a project where I am using the renovation filter to create Alternates for a new School project. I use the New construction for the base bid and the demolition plan for the alternate(S). I noticed that when I create an IFC file it does not "respect" the current renovation status. I get ALL the model regardless of their renovation filter(s). Is there a way to filter out certain model components based upon their renovation filter status?
As a work around, I created two files and deleted all the model components on the Demo filter to create the Base Bid and deleted the New components to create the Alternate. Hopefully there is a better way.
Thanks
2 REPLIES 2
Bruce
I ama away from my computer, so can't check this - but I believe if you save as from the 3D window, it will only save out the visible elements.
Bruce Walker
http://www.brucepwalker.com
https://www.mindmeister.com/65450406
-- since v8.1 --
AC22 6025 INT Full | macOS Mojave 10 | 3.2 GHz Intel Xeon W | 32 Gb RAM | Radeon Pro Vega 56 8 Gb
dderr1234,
In which ARCHICAD version is this happening?
Could you also post a few screenshots of how it looks in ARCHICAD and how the exported IFC looks in a Viewer application? (The forum allows one attachment per post).
Laszlo Nagy, Lead Moderator, Community Admin
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
