IFC Export from Revit for MEP
Has anyone got settings / suggestions for using the Revit Connection plug-in to export IFCs from Revit that translate Revit MEP objects (families) to native Archicad MEP objects. In our tests so far, even the piping comes in as non-native objects.
Think Like a Spec Writer
AC4.55 through 27 / USA AC27-4060 USA
Rhino 8 Mac
MacOS 14.2.1
1 REPLY 1
For the plugin to work correctly, the modeler must know how to assign the right classifications to the right occurrences. Then when importing into Archicad it is necessary to have the MEP module or the latest version 24. The import translator of the IFC file will also be determined so that the file exported from Revit is correctly interpreted. I do not know what this plugin means into Revit.
For my part, I prefer to modify all IFC translators in order to master the consequences.
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
"Quality is never an accident ; it's always the result of an intelligent effort" John Ruskin
Learn and get certified!
