Collaborate forum
IFC Library Objects only show on the lowest storey
fuzzytnth3
IFC Library Objects only show on the lowest storey of the Model despite being linked to a higher storey. In the attached screenshots you can see the settings for these objects so they should not be visible on the -3 Datum storey but they are.
The only solution I can think of is if I convert them to morphs and see if they will behave then. Anyone else had this issue?
AC versions 3.41 to 25 (UKI Full 4013).
Using AC23 6004 UKI FULL
2 REPLIES 2
fuzzytnth3
Converting them did make them behave but sometimes that can create a lot of polygons. In this case it didn't but seems like something that should work but isn't
Minh Nguyen
Graphisoft Moderator
Hello,
Thank you very much for your question and I am very sorry for the experience!
To better identify the issue, could you let me know a -step-by-step method how to reproduce it? This will be a huge help for us if we can easily recreate the issue in-house!
Looking forward to hearing from you!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
