IFC MEP model: "link vs open" geometry conversion ISSUE
daviddelven
Hello,
Since we discovered what we show here, we federate other disciplines into our AC model with the following workflow:
0. Revit MEP exports IFC using ARCHICAD Connection Addin.
1. Open IFC model directly from AC using Revit MEP translator.
2. Switch on the IFC Revit MEP imported layers.
3. Create a *.pln within this converted IFC model.
4. Open your ARCH Archicad model
5. Link as a module the previous *.pln
The result of geometry conversion is successful with this workflow while linking directly the IFC file as a module doesn't convert 100% of geometry.
Does anyone know why is happening that? The IFC linking option was a great feature in AC21, but it doesn't seem is working quite well as a real tool in a real openBIM workflow.
Thanks
David Delgado Vendrell
http://www.daviddelgado.cat
i7-7820HK CPU 2,90GHz 32GB RAM
Triple Monitor 17"+25"+32" Nvidia Geforce GTX 1080
SSD+HDD, Win10 Home - 64 ENG
AC18-AC26 INT/SPA (64-bit, latest build)
Surfing with Archicad since 2013
1 REPLY 1
daviddelven
Solved.
When you open an IFC directly, MEP library is loaded.
When you are linking the IFC into a project which hasn't loaded MEP library because is another discipline, some objects are not converted.
So, you need to load MEP Library and the issue is solved.
