IFC Model Exchange with Archicad for Revit LT
Quentin
I found the IFC Model Exchange with Archicad for Revit but it seems not compatible with Revit LT. An error pops up before the installation saying Revit (2022) is not found on the computer. Revit LT 2022 is installed.
Do you have an idea?
TYSM,
Quentin
Mscott
Unfortunately Autodesk do not allow for third party add-ins to be installed for Revit LT, see https://knowledge.autodesk.com/support/revit-lt/troubleshooting/caas/sfdcarticles/sfdcarticles/Revit...for guidance.
They will need to use the native Revit LT IFC Importer to import IFC files.
Mscott
Alright, TYSM for your response 😁
