Collaborate forum
IFC Site Location at Survey Point Position - Archicad 24
Hello,
I would like to know how to select the "IFC Site location (if Survey Point is available)" on the 24 version. I have seen Graphisoft's instructions pointing to the IFC Translator Export, however I have not found where to change this site option in there. I have explored all the Conversion Presets with no success.
I can only find references to previous versions on where to find this.
Thank you in advance
1 ACCEPTED SOLUTION
Solution
It can be found in the Geometry Conversion Dialog.
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
2 REPLIES 2
Solution
Thank you very much!
