IFC elevation stories
GOBA
Is there an option, having already an ArchiCAD file with stories created, to import the levels from an IFC file.
What I mean is that, if I had an ArchiCAD file with Story 1 and Story 2 already created, with elevations 3 meters, and I merge an IFC, I can match stories, but I don’t see how to import the correct elevations.
I could erase the stories from the ArchiCAD files, but I would like to have them for the views already created. Does anyone know how I should proceed? I don’t know if I am missing something.
Regards,
GOBA
ArchiCAD user since November 2109
AC24, Windows 10
Podolsky
Ace
When you open IFC file - ArchiCAD creates stories accordingly to information found in IFC.
If you are merging IFC with another model, made in ArchiCAD, it's better to open IFC as a new file and after hotlink it to the main file. It's safer this way and easier to fix errors in IFC or manage storey height, attributes etc.
Podolsky
Ace
GOBA
Thanks!
AC24, Windows 10
