SOLVED!
IFC elevation stories
GOBA
Is there an option, having already an ArchiCAD file with stories created, to import the levels from an IFC file.
What I mean is that, if I had an ArchiCAD file with Story 1 and Story 2 already created, with elevations 3 meters, and I merge an IFC, I can match stories, but I don’t see how to import the correct elevations.
I could erase the stories from the ArchiCAD files, but I would like to have them for the views already created. Does anyone know how I should proceed? I don’t know if I am missing something.
Regards,
GOBA
ArchiCAD user since November 2109
AC24, Windows 10
1 ACCEPTED SOLUTION
Solution
Podolsky
Ace
When you open IFC file - ArchiCAD creates stories accordingly to information found in IFC.
If you are merging IFC with another model, made in ArchiCAD, it's better to open IFC as a new file and after hotlink it to the main file. It's safer this way and easier to fix errors in IFC or manage storey height, attributes etc.
2 REPLIES 2
Solution
Podolsky
Ace
GOBA
Thanks!
AC24, Windows 10
Learn and get certified!
