Collaborate forum
IFC export "generate new value" in AC 25
Bidaya
Hi everyone
despite digging inside the AC 25 documentation I have an issue I would like to expose.
A sub-contractor asked me to use the "Generate new values" settings for my IFC exports.
He sent me a link to a GS AC 23 help page explaining the method.
I have AC 25 and I don't find the option. The name of the function probably evolved but I don't get it.
Thank you for your help.
5 REPLIES 5
felcunha
What kind of value do you want to generate? Can you put a link to the page explaining the method?
Felipe Ribeiro Cunha
AC 26, macOS Monterey
My client sent me the following link
https://helpcenter.graphisoft.com/user-guide/89330/
and asked me to choose the "Generate new values" option which I cannot find in AC25. Thanks for help.
It seems that this option no longer exists in the IFC Translators Dialog.
I am not certain but there may have been some technical reason for its removal.
My two guesses are:
1. The introduction of IFC4.
2. The introduction of BCF (BIM Collaboration Format) Issue Management workflows, which rely on IFC GUIDs for them to work.
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
felcunha
Found the solution:
Just merge your IFC in an empty file. File -> interoperability -> Merge -> merge from local file...
Select your original IFC. When you re-export it, their elements will have new GUID attributed to them.
😎Works fine.
Thank you !
