2022-02-13 11:27 PM
2022-02-13 11:35 PM
What happens when you go to the IFC translator setup?
Do you have any translators loaded there?
2022-02-14 01:24 AM
2022-02-14 08:36 PM
access the IFC Translators... (see image below for reference)
The IFC Translator Dialogue box will appear (see image below for reference)
you can either create a new IFC Translator or import from an external file. 😎
2022-02-14 09:45 PM
2022-02-14 10:06 PM
2022-02-14 10:18 PM
i see, hopefully some technical guys from Graphisoft can help you sort that out. btw have you been using the latest hotfix for your Archicad?
2022-02-14 11:19 PM
No, I have not downloaded
2022-02-17 04:50 AM
Could it be some kind of permission issue that prevents Archicad from accessing that folder or even creating a new file in that folder?
Sometimes antivirus software erroneously block access to programs, you might want to look into that as well as a possible cause.
