IFC4 Schema, Archicad Building Materials and ED Catalogue
daviddelven
When you export an AC composite, formed by different skins with its own Building Material definitions, you only see the "Name/Description" and "Thickness" when you check the IFC model on a viewer.
In another side, Archicad has its own Material Catalogue (XML file) in order to use it in the EcoDesigner tool (or energy evaluation), linked to Building Material database, but without transferring those properties to IFC Scheme.
At the same time, in Graphisoft AC20 help guide appears (see attached image) the information about TAG and CATEGORIES data of Building Materials are shared as standard IFC Material properties.
The PSets of IFC4 Schema "IfcMaterialProperties" are this: http://www.buildingsmart-tech.org/ifc/IFC4/final/html/schema/ifcmaterialresource/lexical/ifcmaterial...
My question is: Does Graphisoft intend to associate this XML file and its data with the standard Property Sets of IFC 2x4 Schema ?
David Delgado Vendrell
http://www.daviddelgado.cat
i7-7820HK CPU 2,90GHz 32GB RAM
Triple Monitor 17"+25"+32" Nvidia Geforce GTX 1080
SSD+HDD, Win10 Home - 64 ENG
AC18-AC26 INT/SPA (64-bit, latest build)
Surfing with Archicad since 2013
B_E_A_T_
This 'general' question/problem generates a similar specific problem for me - discussed here: https://archicad-talk.graphisoft.com/viewtopic.php?f=12&p=294263#p294263
(sorry for picking up old topics and kind of hijacking them, but either I'm missing out on some basic setting, or David's question is still very relevant... - admin can merge topics if this is more appropriate)
(òÓ,)_\,,/
www.studiov2.be
Archicad 24/25/26
Rhino/Grasshopper
BIMcollab ZOOM
>>> Read my book!<<<
1 REPLY 1
B_E_A_T_
(òÓ,)_\,,/
www.studiov2.be
Archicad 24/25/26
Rhino/Grasshopper
BIMcollab ZOOM
>>> Read my book!<<<
