IfcBuildingElementPartType Name
daviddelven
Is it possible to change the name of the IfcBuildingElementPartType to those Composite sublayers after export IFC using the "Split into parts" option?
I have tried to apply the Rule in the Property Mapping but it doesn't change the name, and it just appears the value of the Building Material defined in that layer.
Thanks
David Delgado Vendrell
http://www.daviddelgado.cat
i7-7820HK CPU 2,90GHz 32GB RAM
Triple Monitor 17"+25"+32" Nvidia Geforce GTX 1080
SSD+HDD, Win10 Home - 64 ENG
AC18-AC26 INT/SPA (64-bit, latest build)
Surfing with Archicad since 2013
agroni
Hi David,
I have already tried that and got a negative response.
The IfcBuildingElementPart and the IfcMaterial are exported in Archicad in one package and cannot be differentiated.
Here an example of my building material appearing in borht ElementPart and Material in the IFC Structure.
... or I hope that someone here comes up with a solution and makes both of us happy
The BIMster @ AllesWirdGut
Currently: Archicad 26
User since Archicad 6.5 (2001)
daviddelven
Hi, man!
Should we wait until IFC5, then?
Let's continue squeezing the data schema!
Cheers
David
